Dear Abaqus users,
I am trying the aforementioned Linkage between Abaqus and Parallel Studio XE 2019. I have found alot of information on how to succeed, unfortunately none of the approaches worked for me. (For example, this one: https://www.researchgate.net/publication/313924098_Linking_ABAQUS_2017_and_Intel_Parallel_Studio_XE2016_Visual_Fortran_in_Windows_10_x64)
When starting Abaqus Command and typing "abaqus verify -user_std" it returns:
"ERROR . Abaqus did not complete successfully. Please see std_user.log for details."
Looking into std_user.log reveals "The command "ifort" is either spelled wrong or could not be found."
I also noticed that, compared to this solution (https://grabcad.com/tutorials/linking-abaqus-and-fortran), when I start up Abaqus, it doesn't seem to properly load Parallel Studio XE. In Step 6 of this link, it says that the Abaqus Command Window should show Parallel Studio on Startup. However, it does not do that for me. Instead it says:
"ifortvars.bat [-arch]
ia32 : Set up for IA-32 target
intel64 : Set up for Intel(R) 64 target
If specified,
vs2013 : Set to use Microsoft Visual Studio* 2013
vs2013shell : Set to use Microsoft Visual Studio* Shell 2013
vs2015 : Set to use Microsoft Visual Studio* 2015
vs2015shell : Set to use Microsoft Visual Studio* Shell 2015
vs2017 : Set to use Microsoft Visual Studio* 2017
If
time is used.
linux : Set to Linux* target.
android : Set to Android* target."
Any ideas on how to solve this?
I am using Abaqus 2018, a Test Version of Parallel Studio XE 2019 and Visual Studio 2017, all on Windows 10.
Edit: I suspect that it's a compatibility issue. I'll try to find an older version of Parallel Studio.
