Hi, I'm wondering where the documentation for knee simulator app is or if there are example models to work through. It is not in the general documentation with CAE. And when I click "help" in the knee app, it directs me to a website page with 404 warning.
My understanding of the workflow is the following, is it correct?
- import the geometry of the component in Designer mode
- select the alignment surface
- use Analyst mode to set up materials properties, meshing, boundary conditions as normal CAE
- set up the testing in the test suite. This I assume would automatically update maybe load, BC, and interactions on the database
- submit and run everything as in CAE
So by the end of the day, it's an add-on tool that features specific boundary conditions and interaction specific in the knee applications?
Also, I would assume that the knee simulator already had some default structures in the library to import the geometry, so that you can only test the part that you're interested in. Are they included? Where would they be?
