Have installed local 3DEX apps DOCs and SIMULIA EstProducts User Assistance locally for last couple years. And Java 8 (JRE) versions have worked fine with continual updates, in both Internet Explorer and Chrome IE Tab extension, to do Searches in both User Assistance. Or at least thru early 2021 installations. R22x 3DEX Apps DOCs install requires Java 11 (JDK), and in making these updates, and clearing out old Java 8's, I no longer get Java working for either User Assistance local DOCs:Searches.
- Java Panel is enabled
- Javahome paths are verified
- IE properties, Privacy, Security tabs, seem same as before.
- New Java JDK 11.0.13 installed (11.0.8 min req'd) for R22x User Assistance installations, with all previous Java 8's removed. Searches didn't work.for the new R22x 3DEX Docs User Assist.
- Went back to to R2021x FD07 User Assist, with latest Java jre-8u311-windows-x64.exe installed - now JDK 11 removed - Search no longer works, as it had earlier 2021 FD with earlier 8.0.301 JRE
Nothing comes up except occasional MS IE note that Java 8 must be installed. So it appears IE browser no longer seeing the new Java, ever since latest Windows and IE 10 ver 20H2 (Sep 2021), were installed. Could be a DS Windows security issue, I don't know. I even turned off pop-up blocker.
Wondering if anyone else have trouble with newest Java 11 rqmt for R22x User Assistance, in either 3DEX Apps DOCs or SIMULIA EstProducts Docs, on a local Windows install.
Thank you !
