Isight not updating array graphs
I'm using Isight to perform a material constitutive model calibration via an inverse analysis.
Basically, I run a simulation on Abaqus then I compare the simulation results with the experimental data via the data matching component.
My main problem is that, after an arbitrary number of iterations, the data matching component stops updating the array graphs that compare the experimental data and the simulation. The analysis keeps on running like normal, however I cannot visualize the results.
Any ideas why?
Thanks in advance.
