Dear all,
I use Isight for optimizing material parameter in Abaqus by data matching the simulation results and experimental data. Before defining the data matching component I defined a Matlab component in order to perform some mathematical operations on Abaqus results. Then I print this data as output file to be used in data matching as simulation results. After I run the optimization task, It seems that isight runs matlab code and update the the output file, but it doesn't use this data as simulation results in data matching. I have attached a simplified model to show my problem. I appreciate it if you can help me.
