Is it possible to use nodal results, other than temperature, from Abaqus Standard as predefined fields in Explicit analysis?
I have nodal results (degrees of freedom 11, 12, and 13) from an Abaqus UEL subroutine, where I am solving coupled heat and moisture transport. I want to use these spatially and temporally varying nodal results in my subsequent mechanical analysis, which is a dynamic explicit step. I'm aware of the possibility of using temperature from a heat transfer analysis as a predefined field in sequential mechanical analysis, which is an explicit step, and any nodal results from standard can be used as predefined fields in subsequent standard analysis. However, I wish to use multiple nodal results, other than temperature, as predefined fields in the subsequent explicit analysis. Is there any way to do this?
Thanks in advance.
