Interaction between steel and hyperelastis
Hello everyone, How I can define interaction between hyperelastic section and steel section? I try tie, but I faced with error like "The volume of 363 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero." while, mesh is regular. and warning "360 nodes have been adjusted more than once. The subsequent adjustments may cause these nodes not to lie on their master surface. The nodes have been identified in node set WarnNodeAdjust." how I can solve this problems? or how I can define interaction between them properly?
