In which Ansys plot can I view Damage results from fe-safe?
I obtained a damage calculation from fe-safe, when completed it gave me the element number with max damage and its value, however when reading the results in ansys in Normal stress X, Y & Z plots the max value listed in those plots don´t correspond to the max value given initially . I suppose Normal stress is not the correct ansys plot to check damage, does anyone know which one should I use?
