This is an Example problem, I liked to rerun this input file, But it shows an error. I have mentioned the error for your reference and also program was given below.
AbaqusException: There are fewer than 2 items on a data line for which a generation sequence (start id, end id, optional increment number) is expected. The keyword in question is related to *ELSET. Please check input data.There are fewer than 2 items on a data line for which a generation sequence (start id, end id, optional increment number) is expected. The keyword in question is related to *ELSET. Please check input data. This occurred while parsing the input file. Run the input file through the batch pre-processor to check for syntax errors.
*ELEMENT, TYPE=CPE4R, ELSET=BLANK
*NSET, NSET=CENTER
1,102,203,304,405
*NSET, NSET=MIDLEFT
203,
*ELSET, ELSET=BLANK_B, GEN
1,100,1
*ELSET, ELSET=BLANK_T, GEN
301,400,1
*ORIENTATION, NAME=LOCAL
1.,0.,0., 0.,1.,0.
1, 0
*SOLID SECTION, MATERIAL=STEEL, ORIENTATION=LOCAL,
ELSET=BLANK, CONTROL=EC-1
*SECTION CONTROLS, NAME=EC-1, HOURGLASS=ENHANCED
*MATERIAL, NAME=STEEL
*ELASTIC
2.1E11,0.3
*PLASTIC
400.E6, 0.0E-2
420.E6, 2.0E-2
500.E6,20.0E-2
600.E6,50.0E-2
*NODE, NSET=REFPUNCH
7000, 0.000, 0.06
*NODE, NSET=REFHOLD
8000, 0.1,0.06
*NODE, NSET=REFDIE
9000,0.1,-0.06
*NSET, NSET=NOUT
REFDIE, REFHOLD, REFPUNCH
