In FEM, we need solve K*u=P, K is global stiffness matrix, u is displacement, P is global load vector.
I want export global load vector, that is the P.
I have a read at the manual, I add follow lines into the inp file.
*STEP
*MATRIX GENERATE, STIFFNESS, LOAD
*MATRIX OUTPUT, STIFFNESS, LOAD, FORMAT=MATRIX INPUT
*END STEP
After add the lines, then run the inp file, I can export the global stiffness matrix, I can see a "Job-1_STIF2.mtx" in the work directory, but there is nothing relate to global load vector. I do not know why the load vector can not be export.
Can anyone help me? Thanks for your time.
The full inp file shown as follow
*Heading
** Job name: Job-1 Model name: Job_my
** Generated by: Abaqus/CAE 2016
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=PART-1
*Node
1, 0., 0., 0.
2, 0., 10., 0.
3, 10., 0., 0.
4, 10., 10., 0.
5, 0., 0., 5.
6, 0., 10., 5.
7, 10., 0., 5.
8, 10., 10., 5.
9, 0., 0., 10.
10, 0., 10., 10.
11, 10., 0., 10.
12, 10., 10., 10.
*Element, type=C3D4
1, 1, 3, 4, 8
2, 1, 3, 8, 5
3, 3, 8, 5, 7
4, 6, 5, 1, 8
5, 6, 1, 2, 4
6, 6, 1, 4, 8
7, 5, 7, 8, 12
8, 5, 7, 12, 9
9, 7, 12, 9, 11
10, 10, 9, 5, 12
11, 10, 5, 6, 8
12, 10, 5, 8, 12
*Elset, elset=Set-1, generate
1, 12, 1
** Section: Section-1
*Solid Section, elset=Set-1, material=MATERIAL-1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=PART-1-1, part=PART-1
*End Instance
*Nset, nset=Set-1, instance=PART-1-1, generate
1, 4, 1
*Nset, nset=Set-2, instance=PART-1-1
1, 2, 5, 6, 9, 10
*Nset, nset=Set-3, instance=PART-1-1, generate
1, 11, 2
*Elset, elset=_Surf-1_S2, internal, instance=PART-1-1
10,
*Elset, elset=_Surf-1_S3, internal, instance=PART-1-1
9,
*Surface, type=ELEMENT, name=Surf-1
_Surf-1_S2, S2
_Surf-1_S3, S3
*End Assembly
** MATERIALS
*Material, name=MATERIAL-1
*Elastic
100.,0.3
** BOUNDARY CONDITIONS
** Name: BC-1 Type: Displacement/Rotation
*Boundary
Set-1, 3, 3
** Name: BC-2 Type: Displacement/Rotation
*Boundary
Set-2, 1, 1
** Name: BC-3 Type: Displacement/Rotation
*Boundary
Set-3, 2, 2
** STEP: Step-1
*Step, name=Step-1, nlgeom=NO
*Static
1., 1., 1e-05, 1.
*Element Matrix Output,ELSET=PART-1-1.Set-1,
DLOAD=YES,File Name=element_matrix_vector,Frequency=1,Output File=User Defined,Stiffness=Yes,Mass=Yes
** LOADS
** Name: Load-1 Type: Pressure
*Dsload
Surf-1, P, 1.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
*STEP
*END STEP
