I am carrying out a contact analysis (surface to surface contact) with use of Abaqus/Explicit, when I submit my job it gets aborted and in errors tab the next things appear:
The cpset or the surface parameter must be specified for history contact output
The nset parameter can only be used for bondstat or bondload output
The problem I am not really sure what should I change/select in my history output request nor was I able to find the precise solution in open search, can anyone briefly summarise what are the likely causes of this problem so that to make the job run? Thanks a lot beforehand!!
Regards
Dmytro
