Hi there,
I would like to use Abaqus as FEA solver for topology optimization for typical heat conduction problem. The problem description is attached as in the picture. May I ask should I use steady state heat conduction problem in Abaqus? Which field output is corresponding to elemental heat conduction matrix Ke? (For elastic problem Ke is the elemental stiffness matrix)
Thank you.
