Handling Objective Values from Parallel Components in Isight DOE
Hi everyone,
I'm working on a DOE in Isight that involves two parallel Abaqus components. Both components use the same set of input variables and produce the same objective functions. However, I'm unsure how Isight handles different objective values for the same set of parameters.
Does Isight average the objective values from the parallel components by default, or does it follow another method?
In the DOE component, I only see a single set of parameters and objectives (not duplicates, as the names of the sets are equal). The input parameters need to be the same for both components to avoid having too many factors in my DOE.
Any guidance on how to properly handle this situation would be greatly appreciated.
Thank you in advance for your help.
Best regards
Abaqus Isight
