Field Output variable : heat flux across an interface
Hello everybody,
I am using Abaqus explicit.
I am running a simulation where a hot droplet touches a cold plate. To model the heat transfer between these two bodies I use a contact conductance property in the interface between them. I would like to know the temporal and spatial evolution of the heat flux that is tranfered from the droplet to the plate. I am not sure if there is a field output variable that can give me this information.
Thanks for your help in advance.
