Error with mesh-to-mesh solution mapping
I got the following error in the DAT file when I tried to map the solution. I am simulating a thin shell structure. For the new analysis, the deformed mesh was imported from the odb file, the element faces were converted to geometry faces (in Part module), section was assigned and the resulting part was meshed with S4R elements. Can someone tell me where I went wrong?
Error: THERE ARE NO VALID ELEMENTS IN THIS ANALYSIS AND THE ORIGINAL ANALYSIS THAT SUPPORT MESH-TO-MESH SOLUTION MAPPING
Thanks very much.
-Harsha Reddy
