Displacement loading superposition - How?
Dear all,
I have a rectangular plate (Shell, S4R) under combined compression and pure shear loading. For the sake of the exercise, I don't want to use force-based loading but displacement-based loading.
In the case of pure shear, the following loading is applied:
Left edge -> u2 = -1
Top edge -> u1 = 1
Right edge -> u2 = 1
Bottom edge -> u1 = -1
This creates a nice uniform stress distribution. Exactly the same as the shear force-based loading (with appropriate scaling).
For the uniaxial compression, the following loading is applied:
Left edge -> u1 = 1
Right edge -> u1= -1
This again creates a nice uniform stress distribution, which again follows the same pattern as the force-based loading scenario (with scaling).
However, for the case of combined loading (shear plus compression), I can't get the correct uniform stress distribution to work. At the corners of the plate, I have 2 displacement fields for the same node, which crashes the solver (Abaqus aborts the job).
Upon superimposing the displacements at those specific nodes (manually assigning the combined displacement to those nodes), the resulting stress field is not uniform and shows quite a bit of noise near the corners (not the numerical artifacts but significantly different stresses). Upon using force-based loading, everything works out nicely; the stresses are "perfectly uniform".
I simply can't wrap my head around this discrepancy. How come the displacement superposition in a linear static analysis still gives weird results, yet the force-based version works perfectly well? (Abaqus 2024HF2)
Any input is highly appreciated!
