Using CST Studio Suite 2023 I would like to run a parameter sweep. In the standard case, only 1D data is available. How do I run multiple simulations where I get 2D/3D Results data for each simulation run. Assume memory isnt a problem because I only perform a few runs. In addition, how could I automatically run a simulation with a set of paramters, export the 3D field data, then change the parameters which deletes the current results and update the model, run another simulation, and so on,...? Is it only possible with a Macro? Is there a Macro available or do I need to code it from scratch? Thanks!!!!!!!!
