Hello everyone, I am now trying to figure out what is happening on my Linux server, I followed the instructions of the manual, and everything works fine about months earlier, but recently, I found that there are errors when I try to run CST Studio Suite with GPU acceleration:
############################# ''' Adaptive port meshing finished. Found Cuda hardware : 1 Found OpenCL Nvidia : 1 Found OpenCL AMD : 0 CPU device usage defined via command line option, using 2 cpu devices. GPU usage defined via command line option, using 1 device. Thread usage defined via command line option, using 30 threads. WARNING: No hardware device detected, solver is started without Hardware Accelerator Device. ''' ################################
Anyone have idea what is happening here? Thank you .
