Hello dear CST users,
I am simulating a 3D cubic Fabry-Perot-like micro-resonator in the optical range using CST Studio Suite . The structure consists of a dielectric cubic cavity (not vacuum) bounded by 6 metal layers on each side. Based on standard theory, the metal thickness should be at least 3 times the skin depth to ensure high reflection, meaning the field does not need to penetrate much into the metal itself. To reduce simulation efforts, CST offers simplified models as Lossy-Metal and 2D thin Panel for coated material (for material thinner than the skin depth).
However, in CST, the Lossy Metal material model applies a surface impedance boundary, which means the field does not actually penetrate through the metal layer in the simulation.
- Would this approach correctly capture the physics of my micro-resonator, or should I consider a different material modeling technique, such as 2D thin-panel or 3D solid to ensure proper field interaction?
Any insights on best practices for modeling metal layers in such optical-range resonators would be greatly appreciated, as I am lost.
Thank you so much,
Gal
