CST - Fluid Domains in CHT solver
Hi, I am trying to simulate a water cooling structure using the CHT solver. I have definded a solid using water material properties. then I definded the fluid domain by defining the input as well as the output face. After that I defined the same faces as openings defining input / output direction as well as flow rate and temperatur.
Problem I have is that the solver gives back an error as follows:
the shape xxxx of material water liquid (20C) (CHT) has a dynamic viscosity, which is noly considered for simulation when occurring in the background material or in a fluid domain. The shape will not be treated as a fluid.
What am I doing wrong?
CST Studio Suite ​​​​​​​
