CST - Efficiently Monitor E/H Fields at Resonance Using CST Microwave Studio F-Solver
Hi everyone,
I'm working on tuning the coupling element of an RF cavity in CST Microwave Studio, and I'd like to monitor the E and H fields at the cavity's resonance frequency using the Frequency Domain Solver (F-Solver).
Here's my current workflow:
  1. Run the F-solver with mesh adaptation enabled.
  2. Identify the resonance frequency by locating the minimum of S11.
  3. Manually add field monitors at this exact resonance frequency.
  4. Re-run the simulation without mesh adaptation (to preserve the mesh and avoid shifting the resonance).
This approach works, but it's not ideal:
  • It requires manual intervention between runs.
  • It duplicates the simulation time.
My questions:
  • Is there a way to do this in one shot within CST Studio Suite  ?
  • Can this process be automated using  Python scripting (ideally) (e.g., extract resonance frequency from S11 and automatically set a field monitor)? and if yes, can someone explain how to do? If not is there another way (VBA or othe CST's scripting interface) ?
  • Any best practices or tips for accurate field monitoring at resonance with the Frequency solver while maintaining mesh consistency?
Thanks in advance for any advice or shared scripts!
Denis :-)
