Hello all,
Does anybody know if there is a simple way to obtain admittance/impedance results while using characteristic mode analysis in the integral equation solver?
As long as the source is a 1V source this should be possible to calculate as all you need is the current on the port and the eigenvalue, however, I haven't been unable to figure this out as trying to sum up the current on the port has been fruitless. The monitor current and voltage check box in the port definition does not output result while using CMA either.
Thanks,
Austin
CST Studio Suite
