create a nodeset for used in getSubset()
Hi
I need your help again. I tried for few days already without success. Thank you so much for your help.
I like to create a nodeset which will be used in getSubset() like below
fop=frame.fieldOutputs['S'].getSubset(region=nodeset_output,position=ELEMENT_NODAL)
Here is the code for creating the above nodeset:
node_region_list=[]
inst = odb_object.rootAssembly.instances['Part1-1']
for NodeLabel in NodeList:
node = inst.getNodeFromLabel(label=NodeLabel)
node_region_list.append(node)
nodeset_output=inst.NodeSet(name='output_nodeset',nodes=node_region_list)
There is an error for last line. The error says: TypeError, nodes, found tuples, expecting odbMeshNodeArray
Thank you so much for your help. I appreciate it.
