I am writing to ask about how to toggle on/off visibility of assigned orientations for anisotropic materials within Simulia Structural Model Creation Setup. When I click on a Solid Section in the drop-down tree and assign a material orientation, a RGB set of axes sometimes appears (see screenshot center), and sometimes does not, unless I select the section in the tree and can it appears in faint blue (see screenshot upper right).
Is there a way to toggle on/off the visibility of these, so that I can quickly visually check that the material orientation of each section is what I have intended?
Thank you!
