I am attempting to turn off the constraint checks in Abaqus before the job runs and I just get a syntax error when I attempt to put the command in the kernel command line. Is this the correct place to specify this request prior to running a job, and if so what is wrong with my syntax? The manual specifies the default for these checks are on, so I assume that I need to specify this command before every job I run if I want to bypass constraint checks; is that correct, they just reset to on and I don't have to specify them to "on" ? Thank you in advance for any suggestions or help.
