Hi All,
I'm trying to use a connector element on the end of a spring and use connector failure so I can model the spring snapping at its breaking load. I'm currently using the LINK connector as below:
... *ELEMENT, TYPE=CONN3D2, ELSET=BREAKCON 101,2,3 *CONNECTOR SECTION, ELSET=BREAKCON, BEHAVIOR=BREAKBEHAVIOR BEAM **LINK *CONNECTOR BEHAVIOR, NAME=BREAKBEHAVIOR *CONNECTOR FAILURE, COMPONENT=1 ,,,1.03E+04 ...
But I'm getting the following Error message:
**ERROR: ONE *CONNECTOR FAILURE OPTION HAS A FAILURE CRITERIA DEFINED FOR COMPONENT 1 WHICH IS A CONSTRAINED COMPONENT. THIS IS NOT ALLOWED IN Abaqus/Standard.
I'm trying to add this feature into a long-standing model that is run on standard, so I can't easily switch to an explicit analysis - is there a way to can get this to work?
