Comprehensive guide on how to terminate an Abaqus job
This is an informative post I'm sharing to help others with an issue I recently dealt with and how to troubleshoot it in different situations.
Knowing how to properly stop a running Abaqus job is crucial, as doing it incorrectly can lead to corrupted files and an inability to restart your analysis. Here is a guide on the correct methods for ending a job, depending on how it was started.
1. Terminating an Interactive Job
If you started your Abaqus job directly from the command line and it's running in that same terminal session, you can simply press Ctrl-C to send an interrupt signal. This is the cleanest and fastest way to stop an interactive job.
2. Terminating a Non-Interactive Job
For jobs that were submitted from CAE or run in the background, you must use the Abaqus command-line interface.
  1. Open a command terminal (like PowerShell or Linux Terminal).
  2. Navigate to the job directory where you initially launched the analysis. This is critical because Abaqus needs to access specific job files to properly terminate the process.
  3. Run the terminate command:
    abaqus j=jobname -terminate
    Replace jobname with the actual name of your job.
3. Using Task Manager as a Last Resort
If you are unable to terminate the job using the command line (e.g., you can't locate the correct directory or the command fails), you can use your operating system's task manager to forcefully end the process.
  • On Windows: Open Task Manager (Ctrl+Shift+Esc), go to the "Processes" tab, and look for an Abaqus-related process like Abaqus/Standard.exe or Abaqus/Explicit.exe. Right-click the process and select "End task."
  • On macOS: Open Activity Monitor (search for it in Spotlight), find the Abaqus process, and click the 'X' button to force quit it.
Note: This method should be used only as a last resort. Forcefully ending the process can corrupt your analysis files and make it impossible to restart the job or salvage any data. It's always best to try the command-line method first.
Answers 0
