Hello! I am starting a new thread so I can better formulate problems I have.:
1. Warning: "The strain increment has exceeded fifty times the strain to cause first yield at 7 points"
Common solution that I found for this problem is to reduce initial step time, as I did in STEP module in incrementation tab and it didnt solve the problem. From the user guide I figured that small initial step size is important so calculation of stifness matrix in every step is needed so we get less dsitortion and more acurate results.
2. In tutorial it is said that this simulation should last aproximatly 180 steps but it prolonged to 380 steps
3. I cant figure out how to display plasticly deformed BLANK in Visualisation
So when I turn on Plot deformed shape or plot contours on deformed shape PUNCH part moves to its place and BLANK part stays undeformed and without stress contour as it didnt react. I didnt find any solution to that problem in User guide so it would be great if someone pointed me to the solution
below you can find mi simulation model. Thanks in advance!
