I have checked Simulia documentation and it seems that I can extract the sensitivities of a specific output field with respect a set of available design parameters (check the attached photo for the available parameters).
My question, is it possible to define a new parameter and extract the sensitivity of an output field with respect to this parameter?.
For example can I extract the sensitivity of the stiffness matrix with respect to defined lamination parameters (which is a function of composite material laminate thickness and fiber orientation angles).
https://docs.software.vt.edu/abaqusv2022/English/SIMACAEANLRefMap/simaanl-c-adjointsensitivities.htm#:~:text=Specifying%20design%20variables-,Unlike%20direct%20design,-sensitivity%20analysis%20(which
