Hi there, someone knows if its possible to get peeqt using getvrm? I am calling it using usdfld, following abaqus manual but I am just getting: "PEEQT is not available for this option" code is fine, because if I change "PEEQT" to "PE" for instance I get the values and analysis runs.
Following the manual PEEQT is marked as ".fil=yes" so according to GETVRM section, it should be possible.
Or perhaps can I calculate PEEQT manually using the "PE" components?
Any advice would be highly appreciated.
Regards!
