Abaqus - RSG dialog boxes interaction
Hi everyone,
I have created a RSG and the files *_plugin.py and *DB.py were generated. I have also registered the plugin in order to be accessible from the “Plug-ins” menu. In the first dialog box that appears, four parameters should be defined by the user. What I want now is that another dialog box pops up when the user presses the “OK” button. The parameters defined in the 1st dialog affect the appearance of the 2nd dialog (e.g. number of rows in a table).
Should I use the RSG plugin to create the second dialog box? If yes, how could I make it popup when the user presses the “OK” button from the 1st dialog? What is the best approach to achieve such behavior?
Thanks in advance
Abaqus ​​​​​​​
