ABAQUS recover error on Linux cluster
I am using Abaqus2020 on a Linux Cluster. Whenever I want to restart a simulation from a previous result, I get the following error:
Traceback (most recent call last):
 File "SMAPylModules/SMAPylDriverPy.m/src/analysis.py", line 1744, in
 File "SMAPylModules/SMAPylDriverPy.m/src/analysis.py", line 1231, in run
 File "SMAPylModules/SMAPylDriverPy.m/src/analysis.py", line 387, in _scanRestartOrImport
 File "SMAPylModules/SMAPylDriverPy.m/src/driverOdbScan.py", line 20, in scan
 File "SMAPylModules/SMAPylDriverPy.m/src/odbPyAccess.py", line 143, in __init__
 File "SMAPylModules/SMAPylDriverPy.m/src/odbPyAccess.py", line 95, in __init__
 File "SMAPylModules/SMAPylDriverPy.m/src/symbolicConstants.py", line 92, in __new__
ValueError: SymbolicConstant name '\\xa3i\\xbc\\x11US_STANDARD' may only contain upper case, digit or underscore
Similar errors have occured a couple of times in this forum without satisfactory solution. It was suggested that the restart files might be corrupted. I made sure that the previos job finishes correctly. However, the previous solution always contains a casename.lck file with the content:
casename.odb
Analysis Input File Processor
Abaqus/Standard Analysis
... which might indicate that the previous solution was not written out correctly.
The error is reproducable with a minimal working example of a very simple Abaqus standalone testcase. I therefore expect it to have something to do with the Abaqus implementation on the cluster.
