I am modelling a concrete-filled steel tubes by taking shell element for tube and solid element for concrete. But as a result, the concrete is penetrating the steel tube which should not happen as steel is stiffer than concrete. I have tried surface to surface contact and shell solid coupling in interaction. But the result is same for both.
