Hello all,
I'm trying to run a restart analysis from the command line and it gives an error code 3221225477.
When I submit the jobs from CAE there is no problem. The simulations run and results are OK.
If I submit the step-1 job from CAE and use the command line to run the restart (step-2) it is also OK.
The problem happens when I run both analysis (full and restart) from the command line.
I think I'm missing some parameter when submitting from the command line, and the files from the full analysis are somehow different from the ones created by CAE.
Can anyone help me?
Thanks.
