Dear all,
I am facing a silly problem, I am doing mesh-to-mesh simualtions and everythings was going smoothly. However, at some point while I was using the command window to perform some remeshing manually I start to get this error, once I submit the analysis the pre.exe wont complete and standard does not start at all. What is making me mad is that this happen at my 5th remeshing, which should be fine and previous remeshing was fine as well. In addition the automated code works! So what is going on? I have no clue on this, I belive is not a technical problem ... but still not 100% sure.
Thank you for any advice!
Analysis initiated from SIMULIA established products
Abaqus JOB 1Stage_RAD_OFF_01_TB_remesh_5
Abaqus 3DEXPERIENCE R2017x
Abaqus License Manager checked out the following licenses:
Abaqus/Standard checked out 5 tokens from Flexnet server gallumbits.elec.gla.ac.uk.
<115 out of 200 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
4/2/2018 10:59:18 PM
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.2.179 Build 20150121
Copyright (C) 1985-2015 Intel Corporation. All rights reserved.
End Compiling Abaqus/Standard User Subroutines
Begin Linking Abaqus/Standard User Subroutines
Creating library standardU.lib and object standardU.exp
End Linking Abaqus/Standard User Subroutines
Begin Analysis Input File Processor
Run pre.exe
*** Error: pre.exe / rank 0 / thread 0 encounted an EXCEPTION_ACCESS_VIOLATION in ABQSMAIomCore.dll (code 3221225477)
ABQSMAIomCore.dll admC_Folder_Binary::ReadItem
ABQSMAIomCore.dll admC_Package::ReadMetaData
ABQSMAIomCore.dll admC_Package::admC_Package
ABQSMAIomCore.dll admC_Pkg_NewSingleThr::admC_Pkg_NewSingleThr
ABQSMAIomCore.dll admC_File::ActivatePackage
ABQSMAIomCore.dll admC_File::CheckOut
ABQSMAAncAdbModule.dll adb_File::GetMetadata
ABQSMAAncAdbModule.dll adb_File::RetrievePackage
ABQSMAAncAdbModule.dll adb_BytePackage::adb_BytePackage
ABQSMAAncAdbModule.dll adb_GPackage::adb_GPackage
ABQSMAAncAdbModule.dll adb_FramePackage::RebootFrameRetrieve
ABQSMAAncAdbModule.dll adb_FramePackageHandler::RetrieveFrame1
ABQSMAStsMapSoln.dll map_Model_odb::map_Model_odb
ABQSMAPreCore.dll mapstate
ABQSMAPreCore.dll pre
ABQSMAPreCore.dll pre_main
pre.exe ???
pre.exe ???
pre.exe BasicLicenser::EndLongTransaction
KERNEL32.DLL BaseThreadInitThunk
ntdll.dll RtlUserThreadStart
4/2/2018 10:59:20 PM
Abaqus Error: The executable pre.exe
aborted with system error code 1073741819.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Begin MFS->SFS and SIM cleanup
4/2/2018 10:59:22 PM
Run SMASimUtility.exe
