I'm working with a model in Abaqus CAE that contains several solid parts. For one of the parts within the assembly, when I was in the mesh module, I accidently set the seed side to something absurdly small. Shortly after during the meshing, Abaqus crashed. I then reopened Abaqus (with and without using the restore), and when I try to go back into the mesh module and navigate to the subject part to change the seed side, Abaqus spins for a while then crashes (I've tried 10+ times). So I'm stuck in a loop, I've tried suppressing the subject part within the assembly via the tree, still crashes when I go into the mesh for that part. I was able to go to the Job module and write an .inp without crash, but if I were to stat fresh and re-import the model as .inp I lose a lot of the geometry entities. Anyone have any ideas?
