3DEXPERIENCE / SIMULIA Flow – Sliding Mesh Rotating Zone “Partial Contact with Surrounding Regions” Error in Propeller Transient Simulation
Hello everyone,
I am running a transient CFD simulation of a propeller in SIMULIA / 3DEXPERIENCE Flow Solver (R2026x) using a sliding mesh rotating zone, and I am consistently encountering the following error:
Rotating zone has partial contact with its surrounding regions. Check the mesh at the interface.
Problem setup
  • Geometry:
    • Propeller inside a cylindrical rotating fluid zone
    • Cylinder embedded inside a stationary outer bounding box
  • Topology:
    • One Rotating Zone Fluid (full cylinder volume)
    • One Stationary Zone Fluid (entire bounding box minus cylinder)
    • One Fluid-Fluid Interface between rotating and stationary regions
  • Physics:
    • Transient
    • Sliding Mesh (not MRF)
    • Turbulence: SST k-ω
  • Boundaries:
    • Propeller → Wall, no-slip, non-inertial
    • Outer bounding box → Default Wall, slip
    • Pressure outlet → 0 Pa gauge
  • Mesh:
    • Hex-dominant mesh
    • Good skewness and angles
    • Aspect ratio is high near boundary layers but solver accepts it
    • Only a few cells flagged for “special treatment”
What I observe
  • Simulation starts and sometimes advances 1 time increment
  • Then stops with:
    • Partial contact error on the rotating zone
  • Info messages show:
    • “unintended non-axisymmetric surfaces”
    • remaining faces assigned to Default Wall Boundary clones
  • This happens even though:
    • The rotating zone is a single closed cylinder
    • The fluid interface is defined
    • There are no gaps in geometry
  • If I switch to MRF, the case runs without errors
Questions
  1. What exactly causes “partial contact with surrounding regions” in sliding-mesh cases?
  2. Does this error mean that some rotating-zone boundary faces are not included in the Fluid Interface, and if so, how can I reliably detect and fix them?
  3. Is it mandatory that 100% of the rotating zone boundary be paired through the Fluid Interface (no default wall faces at all)?
  4. Are high-aspect-ratio boundary-layer cells near the interface known to trigger this error?
  5. Is there a recommended best practice workflow (MRF → Sliding Mesh) to avoid this issue?
Any guidance or diagnostic tips would be greatly appreciated.
Thank you in advance.
