Trying to model a lug and pin with the lug being a 3D deformable part and the pin being an analytical rigid surface. I use a Rigid Body constraint to attach a reference point (which will also be used as my loading point in the 2 direction) to the surface of the pin and define contact between the lug hole face and pin face. Continuously getting the following warning regardless of the deformation restraints that I use to fix the non-2 direction restraints and too many cutbacks error. I set the model up exactly the same way in Abaqus Learning Edition and the model runs to completion.
***WARNING: SOLVER PROBLEM. ZERO PIVOT WHEN PROCESSING NODE 1 (ASSEMBLY)
D.O.F. 2
OVERCONSTRAINT CHECKS:
An overconstraint was detected at node 1 ASSEMBLY_NAME ASSEMBLY. There are multiple constraints
applied directly or chained constraints that are applied indirectly at this node.
A list of nodes and chained constraints between these nodes that most likely lead
to the detected overconstraint can be printed out to the message file by including
*constraint controls, print=yes in the input file.
***WARNING: Solver problem. Zero pivot when processing D.O.F. 2 of 1 nodes.
The nodes have been identified in node set
WarnNodeSolvProbZeroPiv_2_1_1_4_5.
*Surface, type=REVOLUTION, name=Pin_Contact
START, 0.405, 0.2
LINE, 0.405, -0.2
*End Instance
*Node
1, 0., 0., 0.189999998
*Nset, nset=Load_Point
1,
** Constraint: Rigid_Pin
*Rigid Body, ref node=Load_Point, analytical surface=Pin-1.Pin_Contact
*End Assembly
** Name: Load_Point Type: Displacement/Rotation
*Boundary
Load_Point, 3, 3
Load_Point, 6, 6
** INTERACTIONS
** Interaction: Lug_Pin
*Contact Pair, interaction=Contact, small sliding, type=SURFACE TO SURFACE, adjust=0.0
Lug-1.Lug_Contact, Pin-1.Pin_Contact
