How to fix? 3DEXPERIENCE 2021 Problem: Product Configuration is not found through the filter
https://youtu.be/j6AUVXmBMtE
This video demonstrates a filtering issue in 3DEXPERIENCE 2021, where a Product Configuration cannot be found when using the Filter command in the web interface. A 150% structure is opened via Product Finder and displayed in Product Structure Editor. When applying the Filter in Configuration mode (by Model version and Date, with all Variants and Options considered), the structure updates correctly by date. However, the Product Configuration itself is not available for selection as a filter criterion. Manual input through Edit Variant and Options still works, but requires precise matching of parameters to retrieve the correct 100% structure. The issue occurs in the “.../3ddashboard/...” environment. In contrast, in Variant Management under “.../3dspace/...”, Product Configuration search functions correctly.
00:00 – In the 3DE web app "Model Definition", previously created configurations with predefined Variants and Options (Variability) are available for model versions.
00:30 – Opening the 150% structure via "Product Finder" for a specific configuration linked to the model version.
01:13 – Demonstration of the full 150% structure tree in "Product Structure Editor".
01:33 – Running the "Filter" command in "Configuration" mode with criteria "Model version" and "Date", enabling "Consider all options for Variants and Options not selected" (to display objects without assigned Variants/Options).
02:00 – The filtered structure updates by date in "Product Structure Editor", but differs from the configuration opened in "Product Finder", where the structure cannot be opened for the selected date.
02:50 – Product Configuration cannot be found as a filter criterion. Manual input via "Edit Variant and Options" is possible, but correct matching of Variants/Options is required to retrieve the 100% structure for a specific date.
04:30 – Product Configuration search remains unavailable in the ".../3ddashboard/..." web environment. 05:08 – Launching "Variant Management" in a separate tab under ".../3dspace/..." (legacy interface).
06:00 – In "Variant Management", when assigning Product Configuration to a "Unit" under a "Model", the search works correctly in ".../3dspace/..." but does not work in ".../3ddashboard/...".
