Design Review for Desktop - Sectioning using surface. How do I use a surface with multiple faces?
I'm using the "Sectioning using surface" command in Enovia Design Review.
It works well when the surface only has one section (like the wavy surface extruded from a spline in one of the screenshots). When I make a surface with multiple sections, like the second screenshot with an extrusion from a two-line segment sketch, the section looks a little wonky.
I noticed that it doesn't select the entire surface, and I cannot select the surface from the tree, only from the 3D Geometry itself.
So, it only selects one of the faces, and then returns a partially sectioned shape.
Am I missing a preference/setting/step to allow me to select the entire surface?
Any other insights that may help with this behavior?
Interestingly, the user guide page for this command shows an example with a wavy surface, but not a segmented surface. https://help.3ds.com/2026x/english/dsdoc/vdvusermap/review-t-section-alongsurface.htm?contextscope=cloud
I didn't find any results for remedy in the knowledge base or other resources.
Sectioning using surface with a segmented surface, doesn't look correct.
Sectioning using surface with a surface with only one face. Works correctly.
