Draftsight Technical Support,
With having difficulty getting the LT Scaling to be viewed correctly in the Sheet or paper mode that was brought as an Xref file could it be it is not supported.
So, as I continue to work with base files brought in to a another drawing as an external referenced drawing or, as it is commonly called an Xref. The drawing exists that the all line types do not appear correctly, no matter that variable "ENBLVPLSCL" is set to either 1, or 0.
In the model tab you can not tell either, unless you zoom in really close. In paper mode is there another setting needed to view them correctly.
If I were to draw a line in the sheet mode, or the paper space it appears as the Linetype definition should correctly
be seen, but that is the extent of it. Is there another LT variable with in the view port for an xref to have the line types appear as they should correctly.
With the Architectural & Engineering field it is very important to the xref .dwg be conveyed as the line types to tell the story.
FYI: I have added files for reference too
Still would appreciate an answer on this asap as I need to plot some drawings this week.
