Hello every body
If I use the command "-insert" (in the command windows), I can't insert my block when I tape the name without the extension "dwg".
I must put the name with the dwg extension (for every blocks) and it's not easy when there are a lot of blocks to insert.
Is there a setting to allow to use the block's name without the extension ?
Very thanks for your answer
bruno
