when using the command -EDITBLOCKATTRIBUTE is there a way to keep the order of selection
Hi
I have a script i'm using to modify block attributes (-EDITBLOCKATTRIBUTE) or the(autocad command -attedit ) in AutoCad  the order of selection was kept so it was easy to make a incremental change to a group of blocks values not requiring the need to see which block value you were changing.
But in draft sight no mater how I select the block order there is no specific way I can keep them in the order I selected them, it just jumbles the order then you need to look for the italicized font to know which one you are working on so you can put the correct value in.
Looking for help
Thanks Larry
