I have seen some questions already related to blank screen / not visible objects where either there was no solution given or the solution was the driver update of the graphics card.
I have similar problem when I try to use DraftSight on a remote desktop, so when I open a drawing or create a new, there are all the objects on the screen but not visible, only when I select them. Changing colour doesn't help.
When I use the computer on the place, everything is visible. When I use the other computer at home with the program installed on it, also everything is visible. However, when I connect to the first computer from the second one with RDP service, the problem appears.
It is a big problem for me as we changed at the company to thin client architecture and there the same happens as thin clients have similar behaviour like RDP connections so there is no possibility to install the program. The program is installed on a Windows Server 2008 R2 Datacenter 64bit.
Did anyone face similar problem and found a solution for that? Or is there no possibility for that?
Every help is appreciated.
Gergely
