To all,
I edited an existing titleblock with attributes that will include the standard items from the Drawing Properties (i.e., Title and Author) plus custom properties ( I created Customer and CustomerAdd).
The items appear in the Default field selection. and I selected them.
When I insert the Titleblock into a new drawing, the fields that represent items from the Drawing Properties display "OBJ" in a dotted box.
How do I use these? I really want to use the Drawing Properties to populate the titleblock automatically.
Thanks in advance,
Robert Hanrahan
Update:
I do not think that this is the right solution but I discovered that if I created the attribute from scratch, there is no problem. If I then go in and decide to change the Default to something else, the field does not update and displays "OBJ" when inserted.
So I went through the Titleblock and changed all the affected attributes and it is working as expected.
As I said, not the right solution....
