Units and scale when I print
Good afternoon all,
Thanks for creating this environment. I´m starting with Draftsight and I need to change the drawing units to meters. I´ve seen some tutorials and in Manage, Drawing, Units... I arrive to Drawing Settings, Unit System and I change "Block Unit Format" from milimeters to meters. Is this the way to draw in meters?
I´ve made an example of a drawing and when I print, trying to see if the units are correct, I select the plotter, the page size A4 and in Scale, when I select 1:1 scale it says 1 mm or inches = 1 unit. Then I print, and in the page, the drawing is in milimeters in scale 1:1. How can I select a minimizing scale 1: X in meters? I only want to draw in meters and print in a scale, for example, 1:500, and see it in A4 in the correct scale while the drawing is in meters.
Thanks in advance,
Jokin
