Working with drawings originally created in AutoCAD, I am unable to make any changes to viewports.
None of the things one would want to do with a viewpoint are possible. They are hidden, cannot be un-hidden. Cannot be deleted, If you double click inside a viewport it’s possible to select the model/drawing within them, but then you’re stuck inside the viewport and cannot unselect it. Only way to become 'un-stuck' from the model/drawing within the viewport is by closing the drawing…
If the layer the viewports are located on are unlocked/thawed using autoCAD everything is fine and your able to manipulated viewports with gay abandon in draftsight. Alas I don’t not have access to AutoCAD, So I’m stumped.
Maybe I’m misinterpreting the way that viewports and/or layers are controlled in draftsight.
Only alternatives are deleting the page and recreating the layout all over again, which isn’t really an option.
Hope someone can shed some light on this. Thanks
