Cannot edit saved files but can add new lines etc and edit them.
I'm running newly updated DraftSight 2017 SP1 on Win8.1 Pro, 32-bit.
Everything worked fine before the update and Hotfix.
Now when I open old files, I can add new lines, etc but the old drawing cannot be edited.Select(ing), etc doesn't work.
I've tried all likely Layers Manager options, to no avail.
Re-saving files under a new name doesn't solve the problem.
Nor did re-installing DraftSight 2017 SP1 from a new download.
Help! please..
ps. it appears to be something to do with DraftSight saves - new lines added can be edited before saving, but not after saving and re-loading. ie they also appear to become "readonly"
.dwg files loaded into Wordpad (as text) are editable, so the file is not really "readonly".
John Macey · 2017-04-27 · Report Abuse
pps. Warren Black kindly responded to my original May question, but we haven't found a solution. I have a tedious "work-around" described in my original (27 May) thread and don't understand how/why it usually works - but there must be a proper solution! - Any help would be appreciated
