SNAP FROM command in Draftsight 2021 SP0 Standard
I have problem with "snap from" command in new version.
EXAMPLE:
Lets have two objects, rectangle and circle. I need move circle to exact position from the corner of the rectangle.
In previous version (DS2020 Standard) I was working this way:
click on the circle
select MOVE command
select from point - click on the center of circle
Specify destination: click on the SNAP FROM command
Click on the desired corner of rectangle
move pointer along desired axis (ORTO ON helps)
Write number (for example 10)
press enter
The circle is moved to new location exactly 10 mm from the corner.
In the 2021 version command SNAP FROM works another way. How to use it?
