smartleader dimension scale according to sheet doesn't work
I have defined a dimension style which scales the dimension geometry according the sheet and this works fine with ordinary dimensions. (I can use the same style with different scaled viewports when placing the dimensions in sheet view.) But for some reason when placing leaders they are scaled 1:1 whatever scale is used in viewport. A workaround to this is to set DIMSCALE variable manually to viewport's scale but I think leaders should also be scaled to viewport's scale, shouldn't they?
Cheers,
Jani
